Enhanced privacy
The DICOTA Secret display privacy filter with corner fixation set is designed to keep sensitive information on your screen from prying eyes, ensuring that your data remains confidential. -
Versatile compatibility
This privacy filter is compatible with a wide range of monitors, making it a flexible solution for enhancing the security of your computer setup.
- DICOTA Secret display privacy filter corner fixation set
- Product Type
- Display privacy filter corner fixation set
- Transparent
- 19 cm x 0.1 cm x 12 cm
- 80 g
- Product Type
- 19 cm - 0.1 cm - 12 cm
- 80 g
- Transparent
Dicota Secret - Corner Fixation Set
