                Enhanced privacyThe DICOTA Secret display privacy filter with corner fixation set is designed to keep sensitive information on your screen from prying eyes, ensuring that your data remains confidential.
                Versatile compatibilityThis privacy filter is compatible with a wide range of monitors, making it a flexible solution for enhancing the security of your computer setup.
- DICOTA Secret display privacy filter corner fixation set
- Product Type
- Display privacy filter corner fixation set
- Transparent
- 19 cm x 0.1 cm x 12 cm
- 80 g
- Product Type
- 19 cm - 0.1 cm - 12 cm
- 80 g
- Transparent
