Dicota Secret - Corner Fixation Set
Quicklinx: FS2YWS00 Mfr#: D30194
£6.81 ex VAT
£8.17 inc VAT
DICOTA Secret - Display privacy filter corner fixation set - transparent
  • Enhanced privacy
    The DICOTA Secret display privacy filter with corner fixation set is designed to keep sensitive information on your screen from prying eyes, ensuring that your data remains confidential.
  • Versatile compatibility
    This privacy filter is compatible with a wide range of monitors, making it a flexible solution for enhancing the security of your computer setup.
DICOTA Secret display privacy filter corner fixation set
Transparent
19 cm x 0.1 cm x 12 cm
80 g
19 cm - 0.1 cm - 12 cm
80 g
Transparent
Brand: Dicota
