Extremely slim and portable, use it for Tablets, Phones, laptops, GPS and other devices with screen. The anti-static cleaning solution is safety, alcohol-free, ammonia-free and phosphate-free. The Screen Cleaner with its multifunctional design is the ideal accessory to maintain your devices free of dust and fingerprints. Use the microfiber side to wipe the screen and the plastic shell as a phone stand.
- DICOTA Screen Cleaner - screen cleaner for mobile phone, tablet
- Product Type
- Screen cleaner
- Intended For
- Mobile phone, tablet
- Product Material
- Plastic
- 9.5 cm x 2.3 cm x 2.3 cm
- 100 g
- White
- Product Type
- Screen cleaner
- Intended For
- Product Material
- Plastic
- 9.5 cm
- 2.3 cm
- 2.3 cm
- 100 g
- White
