Dicota Raincover HI-VIS 38 litre orange
Quicklinx: HG4HWS00 Mfr#: P20471-11
£13.82 ex VAT
£16.58 inc VAT
The rain cover can be installed on backpacks and is made of a durable coated material that is capable of keeping bags dry even in pouring rain.
Putting on the rain cover is quick and easy. Simply pull it over a backpack, and the elastic material will perfectly conform to the shape of the bag. The rain cover not only provides reliable protection against rain but also ensures good visibility during twilight and at night thanks to its fluorescent materials and 3M reflective strips, which are certified according EN ISO 20471:2013.
  • Durable material
    Constructed from high-quality polyester, this raincover ensures long-lasting protection against water and moisture, keeping your belongings safe in various conditions.
  • High visibility
    The raincover features a hi-vis design with reflective accents, increasing visibility during low light conditions, enhancing safety when out and about.
  • Ample capacity
    With a generous capacity of 38 liters, this raincover fits a wide range of backpack sizes, providing comprehensive coverage for your gear.
DICOTA - raincover for backpack - hi-vis, 38 litre
Raincover
Intended For
Backpack
Protection
Water repellent
Product Material
Polyester
53 cm 65 cm
200 g
Orange
4 years warranty
Raincover
Intended For
Backpack
Protection
Water repellent
Product Material
Polyester
53 cm
65 cm
200 g
Orange
Reflective accents
EN ISO 20471:2013
Limited warranty - 4 Years
Brand: Dicota
