The rain cover can be installed on backpacks and is made of a durable coated material that is capable of keeping bags dry even in pouring rain.
Putting on the rain cover is quick and easy. Simply pull it over a backpack, and the elastic material will perfectly conform to the shape of the bag. The rain cover not only provides reliable protection against rain but also ensures good visibility during twilight and at night thanks to its fluorescent materials and 3M reflective strips, which are certified according EN ISO 20471:2013.
- DICOTA - raincover for backpack - hi-vis, 25 litre
- Product Type
- Raincover
- Intended For
- Backpack
- Protection
- Water repellent
- Product Material
- Polyester
- 50 cm 56 cm
- 170 g
- Yellow
- 4 years warranty
- Product Type
- Raincover
- Intended For
- Backpack
- Protection
- Water repellent
- Product Material
- Polyester
- 50 cm
- 56 cm
- 170 g
- Yellow
- Reflective accents
- EN ISO 20471:2013
- Limited warranty - 4 Years
Dicota Raincover HI-VIS 25 litre yellow
