Dicota Privacy Filter for 21.5" 16:9 Widescreen Monitor
Quicklinx: FP2SWS00 Mfr#: D31313
£32.20 ex VAT
£38.64 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA display anti-glare filter - 21.5"
Display anti-glare filter
Transparent
Display Screen Size Compatibility
21.5"
Product Material
PET
47.7 cm x 0.015 cm x 26.8 cm
30 g
21.5"
Product Material
PET
47.7 cm - 0.015 cm - 26.8 cm
30 g
Transparent
Display Filter
Aspect Ratio
16:9
Scratch Resistant
Bubble-free installation, touch screen compatible, self-adhesive, fingerprint-proof, silicone layer back
Brand: Dicota
