Dicota Privacy filter 4-Way for MacBook Pro 16 retina (2019), side-mounted
Quicklinx: G0RNWS00 Mfr#: D70282
£74.06 ex VAT
£88.87 inc VAT
The 4-way privacy filter is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
DICOTA - notebook privacy filter
Notebook privacy filter - 4-way
Installation Type
Removable - plug-in
Product Material
PET
35.4 cm 22.9 cm
60 g
Display Screen Size Compatibility
16"
Anti-glare, anti-reflective, blue light cutting, touch capable
Apple MacBook Pro (16 in)
Product Material
PET
35.4 cm
22.9 cm
Thickness
0.42 mm
60 g
16"
Display Filter
Privacy Protection
4-way
Installation Type
Removable - plug-in
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
