Enhanced privacy
The DICOTA privacy filter offers bidirectional privacy protection, ensuring your screen is shielded from prying eyes from all directions. Its adhesive installation type means it can be easily applied and removed without leaving any residue, making it perfect for maintaining confidentiality in public spaces or open office environments. -
Durable and clear
Crafted from high-quality PET material, this notebook privacy filter is not only scratch resistant but also has high mechanical resilience. It ensures a crystal-clear view and accurate color reproduction, allowing for an optimal viewing experience without compromising on screen protection. -
Eye comfort
With features like 48% blue light reduction and a low-reflective surface, the DICOTA privacy filter is designed to reduce eye strain during long working hours. Its ability to cut down on harmful blue light while maintaining a crystal-clear view makes it an ideal choice for anyone looking to protect their eyesight. -
Touchscreen compatible
Designed to accommodate the modern user, this privacy filter is touch capable, ensuring that touchscreen functionality is not hindered. The silicone layer back allows for smooth navigation without sacrificing screen protection or privacy.
- DICOTA - notebook privacy filter
- Product Type
- Notebook privacy filter - 4-way
- Installation Type
- Removable - adhesive
- Black
- Product Material
- PET
- 29.35 cm 20.3 cm
- 40 g
- Low-reflective, +/- 30° visible angle, silicone layer back, high mechanical resilience, touch capable, 48% blue light cutting, clear view, accurate colour reproduction, residue free
- 2-year warranty
- Designed For
- HP Elite x360 830 G9 Notebook
- Product Type
- Product Material
- PET
- 29.35 cm
- 20.3 cm
- Thickness
- 0.42 mm
- 40 g
- Black
Display Filter
- Privacy Protection
- 4-way
- Installation Type
- Scratch Resistant
- Limited warranty: - 2 years
- Designed For
