Dicota Privacy filter 4-Way for DELL Latitude 7200 2-in-1, side-mounted
Quicklinx: G0QPWS00 Mfr#: D70184
£52.75 ex VAT
£63.30 inc VAT
Remote working has made notebooks increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The Secret 4-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 4-way technology protects the display from being viewed by prying eyes from all four sides: left/right and top/bottom. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
DICOTA - notebook privacy filter
Notebook privacy filter - 4-way
Installation Type
Removable - plug-in
Product Material
PET
28.7 cm 20.4 cm
40 g
Anti-glare, anti-reflective, easy-to-remove, fingerprint-resistant coating, blue light cutting, high mechanical resilience, touch capable
Dell Latitude 7200 2-in-1
Product Material
PET
28.7 cm
20.4 cm
Thickness
0.43 mm
40 g
Display Filter
Privacy Protection
4-way
Installation Type
Removable - plug-in
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
