Dicota Privacy filter 4-Way for Apple iPad Pro 13.0 2024, side mounted
Quicklinx: HV40WS00 Mfr#: D70860
£54.86 ex VAT
£65.83 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes.
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
  • Effective privacy protection
    The 4-way privacy feature allows for comprehensive coverage, ensuring only the user can see the display from any angle, safeguarding sensitive information.
  • Durable design
    Made from high-quality PET film, this privacy filter is designed to withstand daily wear and tear, providing lasting performance.
  • Enhanced screen comfort
    The anti-reflective coating reduces glare, while blue light reduction minimizes eye strain, making it suitable for prolonged use.
  • Easy installation
    The self-adhesive design allows for straightforward application, so users can enjoy the benefits of privacy and protection without hassle.
  • Complete package
    Included with the privacy filter is a cleaning wipe, ensuring a clean installation process and maintaining clarity over time.
DICOTA Secret - screen privacy filter for tablet - self-adhesive
Screen privacy filter - film - with privacy filter - 4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
21.16 cm 27.76 cm
Thickness
0.42 mm
40 g
Apple 13-inch iPad Pro (M4)
Privacy Protection
4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
21.16 cm
27.76 cm
40 g
Thickness
0.42 mm
Brand: Dicota
