Dicota Privacy filter 4-Way for Apple iPad Pro 11.0 2024, self-adhesive
Quicklinx: HV3PWS00 Mfr#: D70850
£40.00 ex VAT
£48.00 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes.
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
  • Effective privacy protection
    This filter offers 4-way privacy protection, ensuring that your screen is visible only to you while blocking the view from the sides.
  • Easy installation
    The self-adhesive design allows for simple installation and removal without leaving residues on the screen.
  • Durable material
    Constructed from high-quality PET film, this privacy filter is scratch-resistant, ensuring protection against everyday use.
  • Enhanced visual comfort
    The anti-reflective coating minimizes glare, while blue light reduction helps to decrease eye fatigue during extended use.
  • Clean and clear display
    With fingerprint-resistant technology, this filter helps maintain a pristine view while avoiding smudges and fingerprints.
DICOTA Secret - screen privacy filter for tablet - self-adhesive
Screen privacy filter - film - with privacy filter - 4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
17.35 cm 24.57 cm
Thickness
0.42 mm
29 g
Apple 11-inch iPad Pro M4 Wi-Fi, M4 Wi-Fi + Cellular
Privacy Protection
4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
17.35 cm
24.57 cm
29 g
Thickness
0.42 mm
Brand: Dicota
