Dicota Privacy filter 4-Way for Apple iPad Air 13.0 2024, self-adhesive
Quicklinx: HV3DWS00 Mfr#: D70841
£53.49 ex VAT
£64.18 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 4-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 4-way technology protects the display from being viewed by prying eyes from all four sides: left/right and top/bottom. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
  • Effective privacy protection
    The 4-way privacy filter limits the viewing angle, ensuring only the user can see the screen clearly, thus safeguarding sensitive information from prying eyes.
  • Durable and reliable material
    Made from high-quality PET film, this screen privacy filter is scratch-resistant, anti-reflective, and provides long-lasting protection for your tablet screen.
  • Blue light reduction
    Designed to minimize blue light emissions, this filter helps reduce eye strain, making it comfortable for prolonged usage.
  • Easy to apply and remove
    The self-adhesive installation allows for a hassle-free application and easy removal, leaving no residue on the screen.
  • Fingerprint-resistant surface
    The advanced coating prevents fingerprints and smudges, keeping the screen clear and enhancing the visual experience.
DICOTA Secret - screen privacy filter for tablet - 4-way, self-adhesive
Screen privacy filter - film - with privacy filter - 4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
21.1 cm 27.66 cm
Thickness
0.42 mm
40 g
Apple 13-inch iPad Air (M2, M3)
Privacy Protection
4-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
21.1 cm
27.66 cm
40 g
Thickness
0.42 mm
Brand: Dicota
