Dicota Privacy filter 2-Way for Monitor 27.0 Wide (16:9), side-mounted
Quicklinx: FZQ8WS00 Mfr#: D31055
£92.45 ex VAT
£110.94 inc VAT
Protect the sensitive information on your Notebook - and your privacy! Because of the increase in business mobility, notebooks are used everywhere. Especially in public areas, the data on notebook screens is hard to conceal from the view of passer-bys. But Dicota has the solution for you. Secret is a highly effective protective filter for your screen which prevents personal and confidential information from falling into the wrong hands. Secret is directly attached to the screen and fastened with small flaps. The synthetic material consists of fine, black lamellas. Scratches and fingerprints are prevented by the protective filter. Due to the innovative Microlouver technology Secret offers aside from the anti-reflective function, glare protection which allows easy working even in sunshine. Thanks to the viewable angle of up to 30° for each side, the user has an unlimited view onto to the screen, while from the side a black, reflective surface is all that can be seen.
DICOTA display privacy filter - 27" wide
Display privacy filter - 2-way
Installation Type
Plug-in/adhesive
Display Screen Size Compatibility
27" wide
Product Material
PET
59.8 cm 33.6 cm
90 g
27" wide
Product Material
PET
59.8 cm 33.6 cm
90 g
Display Filter
Privacy Protection
2-way
Installation Type
Plug-in/adhesive
Aspect Ratio
16:9
Scratch Resistant
Anti-glare, anti-reflective, blue light cutting, touch capable
Brand: Dicota
