Dicota Privacy filter 2-Way for Monitor 27.0 Wide (16:9), self-adhesive
Quicklinx: HQGZWS00 Mfr#: D70771
£97.26 ex VAT
£116.71 inc VAT
The DICOTA Secret display privacy filter offers an effective solution for maintaining privacy while using a computer monitor. Designed for 24" wide screens, this filter features a 2-way privacy protection system, allowing you to work discreetly in public spaces. The scratch-resistant PET material ensures durability, while the anti-reflective coating enhances visibility. With bubble-free installation and touchscreen compatibility, the product provides a seamless user experience. Its fingerprint-proof nature and silicone layer backing contribute to a cleaner and clearer display while reducing blue light exposure by 43%.
  • Enhanced Privacy Protection
    This display privacy filter features a 2-way protection system that prevents prying eyes from viewing sensitive information on either side of the screen, ensuring confidentiality and security in various environments.
  • Durable Construction
    Crafted from high-quality PET material, this privacy filter is scratch resistant, making it ideal for daily use while maintaining the integrity of your display.
  • User-friendly Installation
    The self-adhesive nature ensures a bubble-free installation, allowing you to easily attach the filter to your screen without hassle or the need for additional tools.
  • Touchscreen Compatibility
    Designed to be touchscreen compatible, this filter does not impede functionality, maintaining responsive touch capabilities while offering privacy.
  • Blue Light Reduction
    With a 43% reduction in blue light exposure, this filter helps to minimize eye strain, making it a practical choice for prolonged computer use.
DICOTA Secret display privacy filter - 24" wide
Display privacy filter - 2-way
Installation Type
Adhesive
Display Screen Size Compatibility
24" wide
Product Material
PET
59.8 cm x 0.23 cm x 33.6 cm
80 g
24" wide
Product Material
PET
59.8 cm - 0.23 cm - 33.6 cm
80 g
Display Filter
Privacy Protection
2-way
Installation Type
Adhesive
Aspect Ratio
16:9
Scratch Resistant
Self-adhesive, silicone layer back, +/- 30° visible angle, 43% blue light cutting, fingerprint-proof, anti-reflective, touch screen compatible, bubble-free installation
Brand: Dicota
