Dicota Privacy filter 2-Way for Monitor 24.0 Wide (16:10), self-adhesive
Quicklinx: HQG9WS00 Mfr#: D70757
£81.48 ex VAT
£97.77 inc VAT
The DICOTA Secret display privacy filter is a solution for those seeking to enhance their screen's privacy and protection. Designed specifically for 24" monitors, this filter features bidirectional privacy protection, limiting the visible angle to +/- 30°, thus keeping sensitive information away from prying eyes. It's not just about privacy; the filter also offers a range of features aimed at protecting your screen and improving your viewing experience. From scratch resistance and high mechanical resilience to accurate color reproduction and an anti-reflective surface, every aspect has been considered. Additionally, the filter supports eye comfort with a 45% blue light cutting feature, reducing the risk of eye strain during long hours of use. Installation is straightforward thanks to its adhesive design, ensuring a bubble-free fit and easy removal without leaving any residue. Whether at the office or working remotely, the DICOTA Secret display privacy filter is a suitable companion for your monitor, combining privacy, protection, and comfort.
  • Enhanced privacy
    The DICOTA Secret display privacy filter offers bidirectional privacy protection, ensuring your data remains confidential with a +/- 30° visible angle. Ideal for high-traffic areas or those who prioritize data privacy.
  • Superior screen protection
    Equipped with scratch-resistant technology and high mechanical resilience, this filter not only protects your screen from daily wear and tear but also maintains a clear view and accurate color reproduction for an optimal viewing experience.
  • Eye comfort
    Featuring a 45% blue light cutting capability, the DICOTA Secret display privacy filter reduces eye strain during prolonged use, making it suitable for both office and remote work environments.
  • Easy maintenance
    This filter boasts a fingerprint-proof surface and allows for bubble-free installation and ease of removal, thanks to its self-adhesive, silicone layer back. It leaves no residue, ensuring your screen stays clean and clear.
DICOTA Secret display privacy filter - 24"
Display privacy filter - 2-way
Installation Type
Adhesive
Display Screen Size Compatibility
24"
Product Material
PET
51.9 cm x 0.0115 cm x 32.5 cm
70 g
24"
Product Material
PET
51.9 cm - 0.0115 cm - 32.5 cm
70 g
Display Filter
Privacy Protection
2-way
Installation Type
Adhesive
Aspect Ratio
16:10
Scratch Resistant
Anti-reflective, bubble-free installation, self-adhesive, fingerprint-proof, +/- 30° visible angle, silicone layer back, high mechanical resilience, 45% blue light cutting, clear view, accurate colour reproduction, residue free, ease of removal
Brand: Dicota
