Due to the increase in business mobility, notebooks have become ever more popular in the last few years. Especially in public areas, the data on notebook screens is hard to conceal from the view of passer-by's. But Dicota has the solution for you! Secret is a highly effective protective filter for your screen which prevents personal and confidential information from falling into the wrong hands.
Secret is directly attached to the screen and fastened with small flaps. The synthetic material consists of fine lamellas. Scratches and fingerprints are prevented by the protective filter. Due to the innovative Microlouver technology Secret offers aside from the anti-reflective function, glare protection which allows easy working even in sunshine. Thanks to the viewable angle of up to 30° for each side, the user has an unlimited view onto to the screen, while from the side a reflective surface is all that can be seen.
- DICOTA display privacy filter - 24" wide
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Plug-in/adhesive
- Black
- Display Screen Size Compatibility
- 24" wide
- Product Material
- PET
- 51.9 cm 32.5 cm
- 80 g
- 2-year warranty
- Product Type
- 24" wide
- Product Material
- PET
- 51.9 cm 32.5 cm
- 80 g
- Black
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Plug-in/adhesive
- Aspect Ratio
- 16:10
- Scratch Resistant
- Material Thickness
- 0.38 mm
- Anti-glare, anti-reflective, blue light cutting, touch capable
- - 2 years
