Dicota Privacy filter 2-Way for Monitor 22" Wide (16:9), side-mounted
Quicklinx: DQZMWS00 Mfr#: D31246
Accessory Type: Privacy Screen
£77.52 ex VAT
£93.02 inc VAT
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints. Remote working has made notebooks increasingly popular. In public places, it is difficult to protect the data on the notebook from being seen by third parties. Dicota has the perfect solution for you! Secret is a highly effective protective film for your screen that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
DICOTA display privacy filter - 22" wide
Display privacy filter - 2-way
Installation Type
Plug-in/adhesive
Display Screen Size Compatibility
22" wide
Product Material
PET
47.6 cm 26.8 cm
60 g
22" wide
Product Material
PET
47.6 cm 26.8 cm
60 g
Display Filter
Privacy Protection
2-way
Installation Type
Plug-in/adhesive
Aspect Ratio
16:9
Scratch Resistant
Material Thickness
0.38 mm
Anti-glare, anti-reflective, blue light cutting, touch capable
Brand: Dicota
