Dicota Privacy filter 2-Way for Monitor 13.4 Wide (16:10), side-mounted
Quicklinx: HQHBWS00 Mfr#: D70780
£34.20 ex VAT
£41.04 inc VAT
The DICOTA Secret display privacy filter is a solution for safeguarding your screen's visibility and protecting your information from unwanted viewers. Designed specifically for 13.4" wide screens with a 16:10 aspect ratio, this filter offers 2-way privacy protection, allowing you to work confidently in any environment. Its reversible design features both glossy and matte finishes, enabling you to choose the viewing experience that best suits your needs. The glossy finish enhances clarity for vivid images, while the matte side significantly reduces glare, making it easier to see your screen in brightly lit conditions.
Crafted with durability in mind, the DICOTA Secret is made from high-quality PET material that is both scratch-resistant and fingerprint-resistant, ensuring your screen stays clear and legible. Additionally, it boasts features like 48% blue light cutting for reduced eye strain and is touchscreen compatible, allowing for uninterrupted use of your device. The filter's easy adhesive installation means you can secure it to your display without any hassle, and it's just as simple to remove, leaving no residue behind. Each package includes cleaning wipes and holders, providing everything you need for a straightforward, bubble-free application. Whether you're working in an office, studying in a library, or browsing in a cafe, the DICOTA Secret display privacy filter offers a blend of privacy, protection, and functionality.
  • Enhanced privacy
    The DICOTA Secret display privacy filter offers 2-way privacy protection, ensuring your screen is shielded from prying eyes. Ideal for maintaining confidentiality and privacy in public spaces or open office environments.
  • Versatile viewing
    Featuring a reversible design with a glossy and matte finish, this filter adapts to your viewing preferences. The glossy side enhances clarity, while the matte side reduces glare, providing comfortable viewing in any lighting condition.
  • Durable and clear
    Crafted from high-quality PET material, the DICOTA Secret is designed for durability and clarity. It's scratch-resistant and has a fingerprint-resistant coating, keeping your screen clear and readable, while also cutting down 48% of harmful blue light.
  • Easy installation
    With its adhesive installation type, the DICOTA Secret is easy to apply and remove without leaving any residue. It comes with cleaning wipes and holders for a hassle-free setup, making it a convenient choice for protecting your device's display.
DICOTA Secret display privacy filter - 16:10 - 13.4" wide
Display privacy filter - 2-way
Installation Type
Removable - adhesive
Package Content
Cleaning wipes, holders
Display Screen Size Compatibility
13.4" wide
Product Material
PET
28.9 cm x 0.038 cm x 18 cm
20 g
Package Content
13.4" wide
Product Material
PET
28.9 cm - 0.038 cm - 18 cm
20 g
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:10
Surface Finish
Glossy/matte
Scratch Resistant
Anti-glare, reversible, fingerprint-resistant coating, touch screen compatible, +/- 30° visible angle, high mechanical resilience, 48% blue light cutting, accurate colour reproduction
Brand: Dicota
