Dicota Privacy filter 2-Way for Microsoft Surface Laptop 5 15.0, side-mounted
Quicklinx: HG3DWS00 Mfr#: D70679
£49.28 ex VAT
£59.13 inc VAT
Remote working has made notebooks increasingly popular. In public places, it is difficult to protect the data on the notebook from being seen by third parties. DICOTA has the perfect solution for you! Secret is a highly effective protective film for your screen that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
  • Enhanced privacy
    With a 2-way privacy protection feature, this notebook privacy filter ensures your data remains confidential, offering peace of mind in public spaces.
  • Durable design
    Crafted from high-quality PET material and equipped with scratch-resistant properties, this filter is built to withstand daily wear and tear while keeping your screen pristine.
  • Eye comfort
    The filter cuts 43% of blue light, reducing eye strain during prolonged use, and features an anti-glare surface, making screen viewing comfortable under various lighting conditions.
  • Touch compatibility
    Designed to be fully compatible with touch screens, this privacy filter allows for uninterrupted touch functionality, ensuring a seamless user experience.
  • Easy application
    Thanks to its adhesive dots mount, the filter can be easily applied, removed, and reapplied without leaving any residue, offering flexibility and convenience.
DICOTA - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Removable - adhesive
Product Material
PET
33.7 cm 23.35 cm
40 g
Anti-glare, 30° visible angle, touch screen compatible, scratch-resistant, fingerprint-proof, adhesive dots mount, 43% blue light cutting
Product Material
PET
33.7 cm
23.35 cm
Thickness
0.38 mm
40 g
Display Filter
Privacy Protection
2-way
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
