Dicota Privacy filter 2-Way for MacBook Air 15 M2 (2022), side-mounted
Quicklinx: HG3BWS00 Mfr#: D70692
£46.56 ex VAT
£55.87 inc VAT
Remote working has made notebooks increasingly popular. In public places, it is difficult to protect the data on the notebook from being seen by third parties. DICOTA has the perfect solution for you! Secret is a highly effective protective film for your screen that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Product Material
PET
33.5 cm 22 cm
40 g
Display Screen Size Compatibility
15"
Anti-glare, touch screen compatible, fingerprint-proof, 43% blue light cutting, limited viewing angle of +/- 30 °, clear view
Product Material
PET
33.5 cm
22 cm
40 g
15"
Finish
Glossy, matte
Display Filter
Privacy Protection
2-way
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
