Dicota Privacy filter 2-Way for Laptop 15.6 Wide (16:10), side-mounted
Quicklinx: HG37WS00 Mfr#: D70686
£36.78 ex VAT
£44.13 inc VAT
Remote working has made notebooks increasingly popular. In public places, it is difficult to protect the data on the notebook from being seen by third parties. DICOTA has the perfect solution for you! Secret is a highly effective protective film for your screen that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed. The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
  • Enhanced privacy
    With a limited viewing angle of +/- 30 °, this privacy filter ensures your data remains confidential, ideal for high-traffic areas or working on sensitive information in public spaces.
  • Versatile viewing
    Featuring both glossy and matte finishes, this privacy filter offers the flexibility to choose your preferred viewing experience. The glossy side provides a clearer view, while the matte side reduces glare and reflections, enhancing visual comfort.
  • Durable design
    Crafted from high-quality PET material and designed to be scratch resistant, this privacy filter stands up to everyday wear and tear, protecting your screen from damage while maintaining its touchscreen compatibility.
  • Eye comfort
    Equipped with a 48% blue light cutting feature, this filter not only protects your privacy but also reduces eye strain, making it ideal for extended use.
  • Easy application
    The removable design, complemented by plastic holders, allows for easy application and removal of the filter, ensuring a secure fit and convenience for users who are on-the-go.
DICOTA - notebook privacy filter - 16:10
Notebook privacy filter - 2-way - 16:10
Installation Type
Removable
Product Material
PET
33.5 cm 20.95 cm
30 g
Display Screen Size Compatibility
15.6"
Anti-glare, anti-reflective, touch screen compatible, fingerprint-proof, plastic holders, 48% blue light cutting, limited viewing angle of +/- 30 °, clear view, accurate colour reproduction
Notebook privacy filter - 16:10
Product Material
PET
33.5 cm
20.95 cm
30 g
15.6"
Finish
Glossy, matte
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:10
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
