Dicota Privacy filter 2-Way for Laptop 12.5" Wide (16:9), side-mounted
Quicklinx: FD6GWS00 Mfr#: D30478
£24.15 ex VAT
£28.98 inc VAT
Protect the sensitive information on your notebook - and your privacy! Beacause of the increase in business mobility, notebooks are used everywhere. Especially in public areas, the data on notebook screens is hard to conceal from the view of passer-bys. But Dicota has the solution for you. Secret is a highly effective protective filter for your screen which prevents personal and confidential information from falling into the wrong hands.
Secret is directly attached to the screen and fastened with small flaps. The synthetic material consists of fine lamellas. Scratches and fingerprints are prevented by the protective filter. Due to the Microlouver technology Secret offers aside from the anti-reflective function, glare protection which allows easy working even in sunshine. Thanks to the viewable angle of up to 30° for each side, the user has an unlimited view onto to the screen, while from the side a reflective surface is all that can be seen.
DICOTA - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Plug-in/adhesive
Product Material
PET
27.7 cm 15.6 cm
20 g
Display Screen Size Compatibility
12.5" wide
Anti-glare, anti-reflective, blue light cutting, touch capable
Product Material
PET
27.7 cm
15.6 cm
Thickness
0.38 mm
20 g
12.5" wide
Display Filter
Privacy Protection
2-way
Installation Type
Plug-in/adhesive
Aspect Ratio
16:9
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
