Dicota Privacy filter 2-Way for iPad Pro 10.5 (2017) / Air 3 landscape, side-mounted
Quicklinx: FZMMWS00 Mfr#: D70130
£30.09 ex VAT
£36.10 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
DICOTA Secret - screen protector for tablet
Screen protector - with privacy filter - 2-way
Intended For
Tablet
Installation Type
Removable - plug-in
Protection
Scratch-resistant
Product Material
PET
17.15 cm 24.8 cm
Thickness
0.38 mm
20 g
Transparent
Apple 10.5-inch iPad Pro
Privacy Protection
2-way
Intended For
Tablet
Installation Type
Removable - plug-in
Protection
Scratch-resistant
Product Material
PET
17.15 cm
24.8 cm
20 g
Thickness
0.38 mm
Transparent
Brand: Dicota
