Remote working has made smartphones increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
- DICOTA Secret - screen protector for tablet
- Product Type
- Screen protector - with privacy filter - 2-way
- Intended For
- Tablet
- Installation Type
- Adhesive
- Screen Size Compatibility
- 10.2"
- Protection
- Scratch-resistant, fingerprint-proof, blue-ray protection
- Product Material
- PET
- 16.9 cm 24.6 cm
- Thickness
- 0.23 mm
- 20 g
- Black
- 2-year warranty
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
- Product Type
- Privacy Protection
- 2-way
- Intended For
- Tablet
- Installation Type
- Adhesive
- 10.2"
- Protection
- Product Material
- PET
- 16.9 cm
- 24.6 cm
- 20 g
- Thickness
- 0.23 mm
- Black
- Anti-reflective
- 2-year warranty
- Designed For
