Dicota Privacy filter 2-Way for HP Monitor E243, side-mounted
Quicklinx: FZM6WS00 Mfr#: D31547
£96.34 ex VAT
£115.60 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA Secret display privacy filter
Display privacy filter - 2-way
Product Material
PET
53.35 cm x 0.038 cm x 29.95 cm
70 g
HP EliteDisplay E243
Product Material
PET
53.35 cm - 0.038 cm - 29.95 cm
70 g
Display Filter
Privacy Protection
2-way
Aspect Ratio
16:9
Scratch Resistant
Anti-glare, touch screen compatible
Brand: Dicota
