Dicota Privacy filter 2-Way for HP Monitor E233 , side-mounted
Quicklinx: FZM5WS00 Mfr#: D31597
£92.26 ex VAT
£110.71 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA Secret display privacy filter
Display privacy filter - 2-way
Product Material
PET
48.25 cm x 0.038 cm x 27.15 cm
60 g
HP EliteDisplay E223
Product Material
PET
48.25 cm - 0.038 cm - 27.15 cm
60 g
Display Filter
Privacy Protection
2-way
Scratch Resistant
Anti-glare, touch screen compatible, fingerprint-proof
Brand: Dicota
