Dicota Privacy filter 2-Way for HP EliteDisplay E190i (5:4), side-mounted
Quicklinx: FZM3WS00 Mfr#: D70147
£69.60 ex VAT
£83.52 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The innovative micro lamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA Secret display privacy filter
Display privacy filter - 2-way
Installation Type
Removable - plug-in
Product Material
PET
37.4 cm x 0.038 cm x 29.9 cm
Product Material
PET
37.4 cm - 0.038 cm - 29.9 cm
Display Filter
Privacy Protection
2-way
Installation Type
Removable - plug-in
Anti-glare, anti-reflective, scratch-resistant, fingerprint-proof
Brand: Dicota
