Dicota Privacy filter 2-Way for Dell U2722DE, side-mounted
Quicklinx: HG2RWS00 Mfr#: D70613
£101.67 ex VAT
£122.00 inc VAT
Protect your data. Secret is a highly effective protective film that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The microlamella technology in the protective film provides glare protection, allowing for relaxed work even when the sun is shining directly on the screen. The user has an unrestricted view of the screen, but from the side, only a black reflective service is visible. The filter also helps to prevent scratches on the screen and reduces fingerprints.
DICOTA display privacy filter
Display privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Product Material
PET
60.83 cm x 0.038 cm x 34.15 cm
120 g
Dell UltraSharp U2722DE
Product Material
PET
60.83 cm - 0.038 cm - 34.15 cm
120 g
Display Filter
Privacy Protection
2-way
Installation Type
Surface Finish
Glossy/matte
Scratch Resistant
Anti-glare, anti-reflective, fingerprint-proof, +/- 30° visible angle, plastic holders, 43% blue light cutting, clear view, accurate colour reproduction
Brand: Dicota
