Dicota Privacy filter 2-Way for DELL Latitude 9330 2-in-1, side-mounted
Quicklinx: HQHVWS00 Mfr#: D70797
£35.92 ex VAT
£43.10 inc VAT
Discover a blend of privacy and protection with the DICOTA notebook privacy filter. Designed for those who value confidentiality and screen integrity, this filter offers bidirectional privacy protection, ensuring your data is visible only to you. Made from durable PET material, it stands up to scratches and everyday wear, while its adhesive installation means you can easily apply or remove it as needed. Not just about protection, it also cares for your eyes by cutting down 43% of harmful blue light and reducing glare with its anti-reflection coating. Plus, its touch capability and accurate color reproduction promise an uncompromised user experience. Whether you're working in a cafe or in the office, maintain your productivity without sacrificing your screen's clarity or your privacy.
  • Enhanced privacy
    With its bidirectional privacy protection, this notebook privacy filter ensures your sensitive information remains confidential, ideal for high-traffic areas and public spaces.
  • Durable design
    Made from high-quality PET material and featuring scratch-resistant properties, this filter is designed to withstand everyday wear and tear while keeping your screen pristine.
  • Eye comfort
    Equipped with a feature that cuts 43% of blue light and an anti-reflection coating, this filter not only protects your eyes from harmful blue light but also minimizes glare, ensuring a comfortable viewing experience.
  • Seamless integration
    Thanks to its adhesive installation, the filter can be easily applied and removed without leaving any residue, maintaining the sleek appearance of your device. Its touch capability ensures that device functionality remains unaffected.
  • Vivid display
    Accurate color reproduction and a clear view feature maintain the vibrant and crisp quality of your screen, enhancing your viewing experience without compromising privacy.
DICOTA - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Removable - adhesive
Product Material
PET
29.35 cm 19.1 cm
30 g
+/- 30° visible angle, 43% blue light cutting, touch capable, clear view, accurate colour reproduction, anti-reflection coating, fingerprint-resistant coating
Dell Latitude 9330 2-in-1
Product Material
PET
29.35 cm
19.1 cm
Thickness
0.38 mm
30 g
Display Filter
Privacy Protection
2-way
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
