Dicota Privacy filter 2-Way for DELL Latitude 7440 2in1, side-mounted
Quicklinx: HQGCWS00 Mfr#: D70759
£39.51 ex VAT
£47.41 inc VAT
The DICOTA privacy filter is a premium computer security product designed to protect sensitive information from unwanted viewers. This notebook privacy filter is equipped with 2-way privacy protection, making it perfect for anyone who values confidentiality and data security. Its scratch-resistant and fingerprint-resistant coatings ensure that your screen remains clear and unobstructed, while the ability to cut 43% of blue light protects your eyes during prolonged use. The filter provides accurate color reproduction and a clear view, thanks to its anti-reflection coating, making it ideal for both work and leisure. Whether you're working in a cafe, on public transport, or in any other high-traffic area, the DICOTA privacy filter keeps your information private. Its easy Plug-and-Play installation means you can effortlessly switch between a glossy or matte finish, depending on your preference, and it's touch-capable, allowing for seamless interaction with your device. Designed for durability and made from high-quality PET material, this privacy filter is an essential accessory for anyone looking to secure their digital life.
  • Enhanced privacy
    The DICOTA privacy filter offers 2-way privacy protection, ensuring your data remains confidential during use. Ideal for high-traffic areas or those moments when you need to keep sensitive information away from prying eyes.
  • Versatile viewing
    With features like +/- 30° visible angle, accurate color reproduction, and clear view, this privacy filter provides a superior viewing experience from various angles without compromising on privacy.
  • Durable design
    Crafted from high-quality PET material, this notebook privacy filter is designed to withstand daily wear and tear. Its scratch-resistant and fingerprint-resistant coatings maintain a clean, unobstructed view.
  • Blue light reduction
    Protect your eyes from harmful blue light without sacrificing color accuracy. The DICOTA privacy filter cuts 43% of blue light, making it easier on your eyes during extended use.
  • Easy installation
    Whether you prefer a glossy or matte finish, the Plug-and-Play installation type allows for quick and easy application or removal of the privacy filter, making it convenient for users who are on-the-go.
DICOTA - notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Removable - plug-in
Product Material
PET
30.8 cm 20.3 cm
30 g
Fingerprint-resistant coating, +/- 30° visible angle, touch capable, 43% blue light cutting, clear view, accurate colour reproduction, anti-reflection coating
Dell Latitude 7440
Product Material
PET
30.8 cm
20.3 cm
30 g
Finish
Glossy, matte
Display Filter
Privacy Protection
2-way
Installation Type
Removable - plug-in
Scratch Resistant
Limited warranty: - 2 years
Dell Latitude 7440
Brand: Dicota
