Dicota Privacy filter 2-Way for Apple iPad Pro 13.0 2024, side-mounted
Quicklinx: HV3YWS00 Mfr#: D70858
£37.40 ex VAT
£44.88 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The protective film is placed directly on the screen. Plastic holders affixed to the edges of the screen keep the filter in place. The filter can be easily removed from the screen as needed.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
  • Strong privacy protection
    The screen privacy filter offers 2-way privacy, ensuring that your screen content is visible only to you and at a close angle, effectively keeping onlookers at bay.
  • Durable material
    Constructed from high-quality PET film, this privacy filter effectively protects your privacy and is scratch-resistant to keep your tablet looking new.
  • Eye comfort enhancement
    With blue light reduction properties, this privacy filter helps to minimize eye strain during long periods of use, making it suitable for work or entertainment.
  • Easy to apply
    Designed for simple self-adhesive installation, this filter can be easily applied and removed without damaging your tablet.
  • Clean and clear
    The package includes a cleaning wipe to ensure your screen is free from smudges and dirt before application, maintaining clarity and protection.
DICOTA Secret - screen privacy filter for tablet - self-adhesive
Screen privacy filter - film - with privacy filter - 2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
21.16 cm 27.76 cm
Thickness
0.38 mm
30 g
Apple 13-inch iPad Pro (M4)
Privacy Protection
2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
21.16 cm
27.76 cm
30 g
Thickness
0.38 mm
Brand: Dicota
