Dicota Privacy filter 2-Way for Apple iPad Air 13.0 2024 Landscape, self-adhesive
Quicklinx: HV3KWS00 Mfr#: D70846
£36.16 ex VAT
£43.39 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
  • Effective privacy protection
    The 2-way privacy feature prevents unauthorized viewing from both sides, ensuring that sensitive information is kept confidential.
  • User-friendly adhesive installation
    The self-adhesive film allows for quick and easy installation without residual glue, making it simple to apply and remove as needed.
  • Durable scratch resistance
    Constructed from PET film, the filter resists scratches from daily use, maintaining clear visibility on the tablet screen.
  • Blue light reduction
    This filter helps reduce blue light exposure, aiding in reducing eye fatigue during prolonged tablet use.
  • Fingerprint protection
    The fingerprint-resistant coating keeps the screen cleaner by preventing smudges, ensuring a clear and unobstructed view.
DICOTA Secret - screen privacy filter for tablet - 2-way, self-adhesive, landscape
Screen privacy filter - film - with privacy filter - 2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
21.1 cm 27.66 cm
Thickness
0.38 mm
20 g
Apple 13-inch iPad Air (M2, M3)
Privacy Protection
2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
21.1 cm
27.66 cm
20 g
Thickness
0.38 mm
Brand: Dicota
