Dicota Privacy filter 2-Way for Apple iPad Air 11.0 2024 Landscape, side-mounted
Quicklinx: HV39WS00 Mfr#: D70838
£28.36 ex VAT
£34.03 inc VAT
Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
  • Effective Privacy Solution
    This screen privacy filter provides a 2-way view, ensuring that only the user can see the contents of the tablet screen, protecting sensitive information from onlookers.
  • Durable Protection
    Constructed from PET film, the filter is resistant to scratches and maintains a clean appearance, ensuring that the screen remains safe from damage.
  • User-friendly Installation
    The self-adhesive installation allows users to conveniently apply the filter without air bubbles, making it easy to achieve a smooth and secure fit.
  • Enhanced Viewing Comfort
    The anti-reflective coating minimizes glare, while the blue light reduction feature helps to alleviate eye strain during prolonged use.
  • Easy Maintenance
    Included in the package is a cleaning wipe, allowing users to maintain screen cleanliness and clarity without hassle.
DICOTA Secret - screen privacy filter for tablet - 2-way, self-adhesive, landscape
Screen privacy filter - film - with privacy filter - 2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
Package Content
Screen protective film, cleaning wipe
Product Material
PET film
17.45 cm 24.36 cm
Thickness
0.38 mm
20 g
Apple 11-inch iPad Air (M2, M3)
Privacy Protection
2-way
Intended For
Tablet
Installation Type
Adhesive
Protection
Package Content
Product Material
PET film
17.45 cm
24.36 cm
20 g
Thickness
0.38 mm
Brand: Dicota
