Remote working has made tablets increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 2-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 2-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 2-way technology protects the display from being viewed by prying eyes from two sides: left/right. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
Effective Privacy Solution
This screen privacy filter provides a 2-way view, ensuring that only the user can see the contents of the tablet screen, protecting sensitive information from onlookers. -
Durable Protection
Constructed from PET film, the filter is resistant to scratches and maintains a clean appearance, ensuring that the screen remains safe from damage. -
User-friendly Installation
The self-adhesive installation allows users to conveniently apply the filter without air bubbles, making it easy to achieve a smooth and secure fit. -
Enhanced Viewing Comfort
The anti-reflective coating minimizes glare, while the blue light reduction feature helps to alleviate eye strain during prolonged use. -
Easy Maintenance
Included in the package is a cleaning wipe, allowing users to maintain screen cleanliness and clarity without hassle.
- DICOTA Secret - screen privacy filter for tablet - 2-way, self-adhesive, landscape
- Product Type
- Screen privacy filter - film - with privacy filter - 2-way
- Intended For
- Tablet
- Installation Type
- Adhesive
- Protection
- Anti-reflective, fingerprint-resistant, scratch-resistant, blue light reduction
- Package Content
- Screen protective film, cleaning wipe
- Product Material
- PET film
- 17.45 cm 24.36 cm
- Thickness
- 0.38 mm
- 20 g
- Black
- 2-year warranty
- Designed For
- Apple 11-inch iPad Air (M2, M3)
- Product Type
- Privacy Protection
- 2-way
- Intended For
- Tablet
- Installation Type
- Adhesive
- Protection
- Package Content
- Product Material
- PET film
- 17.45 cm
- 24.36 cm
- 20 g
- Thickness
- 0.38 mm
- Black
- Limited warranty - 2 years
- Designed For
