Dicota PinPoint Presentation Remote Control
Quicklinx: F52VWS00 Mfr#: D30933
Make a professional impression - Pin Point from Dicota will help you guide your audience confidently through any presentation. Thanks to its non-slip surface, the ergonomic presenter is comfortable to hold. Its operating range of 10 meters allows you to take control of the room. Focus on the content and not on the technology - the intuitive controls make it easy to navigate. The integrated laser pointer allows you to highlight important points. Pin Point is an impressive, easy-to-use pointer. Just plug it in and you are ready to go - the USB receiver will automatically connect to your notebook.
DICOTA PinPoint presentation remote control - black
Presentation remote control
Enclosure Colour
Radio
Supported Devices
Personal computer
Max Operating Distance
10 m
AAA type
Enclosure Colour
Radio
Supported Devices
Personal computer
10 m
Built-in laser pointer
AAA battery
AAA type
