Dicota Pin Point Wireless Laser Pointer
Quicklinx: GX4GWS00 Mfr#: D30933-V1
47 In Stock
£15.56 ex VAT
£18.67 inc VAT
This product complies with the laser classification according to the regulation DIN EN 60825-1. Make a professional impression - Pin Point from DICOTA helps you guide your audience confidently through any presentation. Thanks to its non-slip surface, the ergonomic presenter is comfortable to hold. Its operating range of 10 meters allows you to take control of the room.
Focus on the content and not on the technology - the intuitive controls make it easy to navigate. The integrated laser pointer allows you to highlight important points. Pin Point is an impressive, easy-to-use pointer. Just plug it in and you are ready to go - the USB receiver will automatically connect to your notebook (no software installation required). The receiver can be stored directly inside the presenter when not in use so you can be sure that you have everything you need for your big performance.
  • Integrated laser pointer (class 1)
  • Plug-and-play via USB receiver
DICOTA Pin Point Wireless Laser Pointer - projector pointing device - black
Projector pointing device
Wireless
4 cm x 11 cm x 2.8 cm
300 g
Wireless Receiver
USB wireless receiver
Laser pointer, anti-slip surface
AAA type
Wireless Receiver
4 cm
11 cm
2.8 cm
300 g
Product Material
Acrylonitrile butadiene styrene (ABS)
Input Device
Wireless
Max Operating Distance
Up to 10 m
AAA battery
EN 60825-1, Laser Class 1, Plug and Play
AAA type
Brand: Dicota
