Dicota Perfect Skin 13-13.3"
Quicklinx: HV4RWS00 Mfr#: D31186-RPET
More than 50 In Stock
£14.28 ex VAT
£17.13 inc VAT
For anybody who wants to temporarily transport their Notebook in a light-weight and flexible fashion. PerfectSkin is made of robust and especially elastic neoprene and perfectly adapts to the form of your Notebook like a second skin. It gives the best guaranty against surface scratches and other dents and damages. Another advantage: The zipper is fitted with an extra surface on the inside in order to avoid scratches on the Notebook.
  • Durable construction
    The sleeve is made from neoprene and 100% recycled fabric, providing robust protection while being environmentally friendly.
  • Perfect fit
    Accommodates notebooks sized between 13 inches and 13.3 inches, ensuring a snug and secure hold.
  • Enhanced protection
    Features scratch protection and a water-repellent exterior, designed to shield the device from physical and water damage.
DICOTA PERFECT - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
35 cm x 24.5 cm x 2.5 cm
170 g
Notebook Compatibility
13.3"
Notebook Supported Sizes
13" - 13.3" / 33 cm - 33.8 cm
Lightweight design, scratch protection water repellent
Notebook sleeve
Product Material
35 cm
24.5 cm
2.5 cm
170 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 3 cm
Closure Type
Zipper
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
