For anybody who wants to temporarily transport their Notebook in a light-weight and flexible fashion. PerfectSkin is made of robust and especially elastic neoprene and perfectly adapts to the form of your Notebook like a second skin. It gives the best guaranty against surface scratches and other dents and damages. Another advantage: The zipper is fitted with an extra surface on the inside in order to avoid scratches on the Notebook.
Practical lightweight design
The notebook sleeve is designed to be lightweight, allowing for comfortable carrying without adding bulk. -
Effective scratch protection
With features that offer scratch protection, this sleeve ensures that your laptop's surface remains free from marks and damage. -
Durable water-repellent material
Crafted from neoprene with a water-repellent finish, this sleeve helps protect your laptop from spills and moisture. -
Secure zipper closure
The zipper closure provides a reliable way to keep your notebook safely stored, preventing accidental openings during transit. -
Sustainable recycled fabric
The use of 100% recycled fabric highlights a commitment to environmental responsibility while maintaining quality performance.
- DICOTA PERFECT - notebook sleeve
- Product Type
- Notebook sleeve
- Black
- Product Material
- Neoprene, 100% recycled fabric
- 32.5 cm x 22.5 cm x 2.5 cm
- 150 g
- Notebook Compatibility
- 12.5"
- Notebook Supported Sizes
- 12" - 12.5" / 30.5 cm - 31.8 cm
- Lightweight design, scratch protection water repellent
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- 32.5 cm
- 22.5 cm
- 2.5 cm
- 150 g
- 12.5"
- Notebook Compatibility Dimensions
- 31.5 cm x 21.5 cm x 3 cm
- Closure Type
- Zipper
- Black
- Water repellent
- Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Dicota Perfect Skin 12-12.5"
