Dicota Perfect Skin 12-12.5"
Quicklinx: HV4QWS00 Mfr#: D31185-RPET
47 In Stock
£13.09 ex VAT
£15.70 inc VAT
For anybody who wants to temporarily transport their Notebook in a light-weight and flexible fashion. PerfectSkin is made of robust and especially elastic neoprene and perfectly adapts to the form of your Notebook like a second skin. It gives the best guaranty against surface scratches and other dents and damages. Another advantage: The zipper is fitted with an extra surface on the inside in order to avoid scratches on the Notebook.
  • Practical lightweight design
    The notebook sleeve is designed to be lightweight, allowing for comfortable carrying without adding bulk.
  • Effective scratch protection
    With features that offer scratch protection, this sleeve ensures that your laptop's surface remains free from marks and damage.
  • Durable water-repellent material
    Crafted from neoprene with a water-repellent finish, this sleeve helps protect your laptop from spills and moisture.
  • Secure zipper closure
    The zipper closure provides a reliable way to keep your notebook safely stored, preventing accidental openings during transit.
  • Sustainable recycled fabric
    The use of 100% recycled fabric highlights a commitment to environmental responsibility while maintaining quality performance.
DICOTA PERFECT - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
32.5 cm x 22.5 cm x 2.5 cm
150 g
Notebook Compatibility
12.5"
Notebook Supported Sizes
12" - 12.5" / 30.5 cm - 31.8 cm
Lightweight design, scratch protection water repellent
Notebook sleeve
Product Material
32.5 cm
22.5 cm
2.5 cm
150 g
12.5"
Notebook Compatibility Dimensions
31.5 cm x 21.5 cm x 3 cm
Closure Type
Zipper
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
