Dicota Multi SCALE Notebook Carrying Case 12-14.1" - Black
Quicklinx: DR0VWS00 Mfr#: D31430
Lived sustainability with a clear conscience - SCALE's family of products is manufactured from recycled PET and is kind to the environment. The Multi SCALE offers excellent protection for your devices and is comfortable and easy to carry - designed for daily use, equipped with practical functions that make your life easier.
There's triple protection for your laptop in the lockable main compartment: with surrounding high-density foam padding, a metal-reinforced frame, and reliable fastening thanks to the fastening strap and an adjustable divider. Even your tablet can be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. Documents can fit into the separate slot on the back of the backpack. The comfortably molded riveted carrying handles, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport.
DICOTA Multi SCALE - notebook carrying case
Notebook carrying case
Product Material
600D PET
37.5 cm x 6 cm x 28 cm
780 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 35.8 cm
Foam padding, adjustable shoulder strap, metal frame, lockable
Carrying Strap
Trolley strap, removable shoulder strap, padded top handles
Product Material
600D PET
37.5 cm
6 cm
28 cm
780 g
14.1"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 3.5 cm
Additional Compartments
Mobile phone, pens, tablet, charger
Carrying Strap
Closure Type
Zipper
