Lived sustainability with a clear conscience - SCALE's family of products is manufactured from recycled PET and is kind to the environment. The Multi SCALE offers excellent protection for your devices and is comfortable and easy to carry - designed for daily use, equipped with practical functions that make your life easier.
There's triple protection for your laptop in the lockable main compartment: with surrounding high-density foam padding, a metal-reinforced frame, and reliable fastening thanks to the fastening strap and an adjustable divider. Even your tablet can be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. Documents can fit into the separate slot on the back of the backpack. The comfortably molded riveted carrying handles, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport. Carrying things is actually fun!
- DICOTA Multi SCALE - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 600D recycled PET
- 41.5 cm x 6 cm x 31.5 cm
- 830 g
- Notebook Compatibility
- 15.6"
- Foam padding, elastic fixation straps, lockable notebook compartment
- Carrying Strap
- Trolley strap, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- 600D recycled PET
- 41.5 cm
- 6 cm
- 31.5 cm
- 830 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
- Documents, external pocket
- Carrying Strap
- Black
- Limited warranty: - lifetime
