Dicota Multi Roller PRO 11-15.6
Quicklinx: FS2TWS00 Mfr#: D30924
The fitall system with integrated grip strap and padded separators fixes your 11 - 15.6" notebook and safety brings it to your destination. The sealable notebook pocket, the high density foam padding and the frame reinforced with metal ensure all-round protection. The padded compartment for an iPad or other tablets (up to 10") protects against impact and is equipped with extra-soft nylex inside. Generous storage space for your documents and mobile accessories. The front pocket with key fob and insert pockets allows you to organize your personal equipment. Long-lasting wearing comfort thanks to comfortable and riveted handles, adjustable, padded shoulder strap and the practical trolley fastening strap. Trolley with high-quality replaceable wheels and integrated telescopic handle.
DICOTA Multi Roller PRO Laptop Bag 15.6" - trolley
Trolley
Product Material
Polyester, HDF
45 cm x 25 cm x 37 cm
3.5 kg
Notebook Compatibility
15.6"
Adjustable shoulder strap, padded shoulder strap, reinforced frame, elastic strap fastening, slip pocket wheels, lockable
Carrying Strap
Hand grip, shoulder carrying strap, trolley strap
Trolley
Product Material
Polyester, HDF
45 cm
25 cm
37 cm
3.5 kg
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, power adapter, documents, pens, clothing, business cards, mobile accessories, Apple iPad
Carrying Strap
Wheels, lockable
Limited warranty: - 2 years
