Dicota Multi PRO 11-14.1
Quicklinx: FS2RWS00 Mfr#: D30849
The fitall system with integrated grip strap and padded separators fixes your 11 - 14.1" notebook and safety brings it to your destination. The sealable notebook pocket, the high density foam padding and the frame reinforced with metal ensure all-round protection. The padded compartment for an iPad or other tablets (up to 10") protects against impact and is equipped with extra-soft nylex inside. Generous storage space for your documents and mobile accessories. Two extra document compartments at the back. The front pocket with key fob and insert pockets allows you to organize your personal equipment. Long-lasting wearing comfort thanks to comfortable and riveted handles, adjustable, padded shoulder strap and the practical trolley fastening strap. More than 20 years' experience combined in one bag!
DICOTA Multi Pro Laptop Bag 14.1" - notebook carrying case
Notebook carrying case
Product Material
Polyester, HDF
38 cm x 13 cm x 29.5 cm
1.2 kg
Notebook Compatibility
14.1"
Adjustable shoulder strap, zipper pocket, padded shoulder strap, elastic strap fastening, slip pocket lockable
Carrying Strap
Shoulder carrying strap, trolley strap
Product Material
Polyester, HDF
38 cm
13 cm
29.5 cm
1.2 kg
14.1"
Notebook Compatibility Dimensions
34 cm x 24.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, power adapter, documents, pens, business cards, mobile accessories, Apple iPad
Carrying Strap
Lockable
Limited warranty: - lifetime
