Dicota Multi Plus SCALE Notebook Carrying Case 14-15.6" - Black
Quicklinx: DR10WS00 Mfr#: D31439
Lived sustainability with a clear conscience - SCALE's family of products is manufactured from recycled PET and is kind to the environment. The Multi Plus SCALE offers excellent protection for your devices and is comfortable and easy to carry - designed for daily use, equipped with practical functions that make your life easier.
There's triple protection for your laptop in the lockable main compartment: with surrounding high-density foam padding, a metal-reinforced frame, and reliable fastening thanks to the fastening strap and an adjustable divider. Even your tablet can be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. Documents can fit into the additional zippered compartment on the back of the backpack. The comfortably molded riveted carrying handles, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport.
DICOTA SCALE Multi Plus - notebook carrying case
Notebook carrying case
Product Material
600D PET
Product Recycled Content
Made of recycled polyethylene terephthalate (PET)
41.5 cm x 8.5 cm x 31 cm
840 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Removable shoulder strap, adjustable shoulder strap, padded shoulder strap, reinforced frame, elastic strap fastening, adjustable dividers, lockable notebook compartment, padded notebook compartment, up 10.5" tablet support
Carrying Strap
Shoulder carrying strap, trolley strap, top carry handle
Product Material
600D PET
41.5 cm
8.5 cm
31 cm
840 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Tablet, front external zipped pocket, back zippered pocket
Carrying Strap
Closure Type
Zipper
Lining Material
High-density foam
Limited warranty: - lifetime
