Live smart with Multi Plus Base! The handy clamshell case with additional document compartment protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately.
Your 14-15.6" notebook is not only optimally protected, it can also be securely fixed into the compartment using a strap. You can store documents in the provided zipper compartment. The front pocket with slip pockets allows you to organize your personal items such as mobile phone and pens. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
- DICOTA Multi Plus Base Laptop Bag 15.6" - notebook carrying case
- Product Type
- Notebook carrying case
- Product Material
- Polyester
- 41.5 cm x 8 cm x 19.5 cm
- 900 g
- Notebook Compatibility
- 15.6"
- Zippered, removable shoulder strap, metal frame, front external pocket, zippered internal pocket
- Carrying Strap
- Trolley strap, top carry handle
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 41.5 cm
- 8 cm
- 19.5 cm
- 900 g
- 15.6"
- Notebook Compatibility Dimensions
- 38 cm x 26.5 cm x 4 cm
- Additional Compartments
- Documents, pens, mobile accessories
- Carrying Strap
- Limited warranty: - lifetime
