Dicota Multi Plus BASE 14-15.6 - Black
Quicklinx: DJKZWS00 Mfr#: D30491-V1
Live smart with Multi Plus Base! The handy clamshell case with additional document compartment protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately.
Your 14-15.6" notebook is not only optimally protected, it can also be securely fixed into the compartment using a strap. You can store documents in the provided zipper compartment. The front pocket with slip pockets allows you to organize your personal items such as mobile phone and pens. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
DICOTA Multi Plus Base Laptop Bag 15.6" - notebook carrying case
Notebook carrying case
Product Material
Polyester
41.5 cm x 8 cm x 19.5 cm
900 g
Notebook Compatibility
15.6"
Zippered, removable shoulder strap, metal frame, front external pocket, zippered internal pocket
Carrying Strap
Trolley strap, top carry handle
Product Material
Polyester
41.5 cm
8 cm
19.5 cm
900 g
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Documents, pens, mobile accessories
Carrying Strap
Limited warranty: - lifetime
