Live smart with Multi! The handy clamshell case protects your notebook perfectly thanks to the cushioned notebook compartment. This lightweight notebook case guarantees flexible mobility - both professionally and privately. A stylish, wireless mouse design scores well in any kind of business environment with its optical LED sensor featuring a resolution of 1000 dpi. Three buttons including the scroll function make for easy handling.
Your 15.6" notebook can also be fixed securely in the compartment using a strap. The front pocket provides space for accessories, so all your important items are handy at all times. The shoulder strap is removable. Thanks to its convenient carry handle, the case is comfortable to hold and can be instantly fastened to the trolley using the integrated strap - the smart case from the lightweight class! Just plug and play, the mouse is ready for use in an instant.
Enhanced durability
Crafted from 300D polyester, this notebook carrying case offers protection against daily wear and tear, ensuring your essentials remain secure and intact. -
Optimal compatibility
Designed to accommodate notebooks up to 15.6 inches, the case features a lockable notebook compartment, making it a fit for a wide range of laptop models. -
Organizational efficiency
With additional compartments for a cellular phone, documents, pens, and a power bank, along with internal pockets, this carrying case keeps your items neatly organized and easily accessible. -
Comfortable portability
Equipped with a padded removable shoulder strap and a top carry handle, this case offers versatile carrying options to suit your comfort preference. -
Travel-friendly design
The back trolley straps and a front pocket add convenience to your travels, allowing for easy attachment to luggage and quick access to frequently used items.
- DICOTA Multi Wireless Mouse Kit - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 300D polyester
- 41 cm x 6.5 cm x 29.5 cm
- 690 g
- Notebook Compatibility
- 15.6"
- Internal pockets, lockable notebook compartment, front pocket, back trolley straps
- Carrying Strap
- Top carry handle, padded removable shoulder strap
- 2-year warranty
- Bundled with
- Wireless optical mouse
- Product Type
- Product Material
- 300D polyester
- 41 cm
- 6.5 cm
- 29.5 cm
- 690 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
- Mobile phone, documents, pens, power bank
- Carrying Strap
- Black
- Bundled with
- Limited warranty: - 2 years
