Dicota Multi BASE Laptop Bag 15.6" - Blue
Quicklinx: DF6PWS00 Mfr#: D30919
Live smart with Multi BASE! The handy clamshell case protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately. Give your life a little color.
Your notebook is not only optimally protected, it can also be fixed securely in the compartment using a strap. The front pocket provides space for accessories. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
DICOTA Multi BASE Laptop Bag 15.6" - notebook carrying case
Notebook carrying case
Blue
Product Material
Polyester
Notebook Compatibility
15.6"
Padded, removable shoulder strap
Carrying Strap
Hand grip, shoulder carrying strap, trolley strap
Product Material
Polyester
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, pens, personal accessories
Carrying Strap
Blue
Limited warranty: - lifetime
