Your 15 - 17.3" notebook is not only optimally protected, it can also be securely fixed into the compartment using a strap. The front pocket provides space for accessories. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
- DICOTA Multi BASE Laptop Bag 17.3" - notebook carrying case
- Product Type
- Notebook carrying case
- Grey
- Product Material
- Polyester
- Notebook Compatibility
- 17.3"
- Padded, removable shoulder strap
- Carrying Strap
- Hand grip, shoulder carrying strap, trolley strap
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 29.5 cm x 4.5 cm
- Additional Compartments
- Mobile phone, pens, personal accessories
- Carrying Strap
- Grey
- Limited warranty: - lifetime
